configure snmp sysLocation
configure snmp syslocation sysLocation
Description
Configures the location of the switch.
Syntax Description
sysLocation An alphanumeric string that specifies the switch location.
Default
N/A.
Usage Guidelines
Use this command to indicate the location of the switch. A maximum of 255 characters is allowed. The allowed character set is A-Z, a-z, 0-9, +-@_.,:;()/ ”.
To view the location of the switch on the switch, use the show switch command. The show switch command displays switch statistics including the location of the switch.
The following example configures a switch location name on the system:
configure snmp syslocation englab
The following output from the show switch command displays englab as the location of the switch:
SysName:        engineeringlab
SysLocation:    englab
SysContact:     FredJ
Platform Availability
